jamminvr6storm
12 or 15psi ??
When I bought my Vortech i was given a few pulleys as part of the deal, I want to upgrade my 8psi one for a 10psi....
Can anyone tell me if the pulley in the attached pic is 12 or 15psi?
Also, whats the size of the 10psi pulley?
that must be 15psi... im selling a 2.25" which is my old 12psi pulley
Thanks for that fella, I should be able to calculate the pulley size i need now....
If anyone has a 10psi pulley and can confirm the size or they want to sell it please let me know :D
see now, i'm running a bigger cooler so maybe dropping some pressure due to its volumes - i stayed safe at 11psi at about 47mm
i have 4 pulleys i could do a swap with you if you know the size you want...
I *believe* i need a 2.5" (63.5mm) to achieve 10psi ? Would settle for 60mm....
Got anything near there H8RRA ?
You must have a big FMIC then fella ? It looks like the pulley you have atm if 47mm is only 2/3mm bigger then this one ?
