Lora_G60
Corrado Rear calipers
Early Corrado's use the same as late MK2 then they changes to MK3 in 1993 sometime...
They all fit tho but MK4 is the way to go!
Are the mk2 calipers cheaper then the corrado ones, albeit being the same.
Are the Mk4 calipers a straight swap bar the brake hose and carriers?
You need to change the brake hoses to some special ones from C+R enterprises, they're about £40 IIRC otherwise straight swap
The carriers to be swapped too?
IIRC those hoses are a pain to get?
