chrisr
sump gasket
Hi all just noticed there seems to be quite a bit of a oil leak on the sump of my 2.0 16 valve corrado, just wondering how easy are they to change? thanks
yeah easy job,you will need a 1/4 drive socket and extension to reach the bolts near the gearbox end
and dont over tighten the bolts when re fitting..it can bend the sump
is there anything that i need to remove to get to the sump? ill be hopefully doing it on sunday.
