nathan.g4
What and Where are these supposed to go ????
Some stupid joey before me un-plugged these or something and i cant see were they are supposed to go any help would be great. :confused4:Loose wires.JPG[/attachment:1c0zw7ym]
the one with the white plastic connector should have the opposite white plastic connector to plug into somewhere behind/around the ignition coil.
I just been out to look at mine and that's what mine has.
Aye, if its a valver the red/black wire should be plugged in to the same colour...
Its unplugged when you set the ignition timing.
Neil. :)
Okay thanks but wat about the other wire ti has been cut i have had a look but still couldnt see were it is supposed to go? :help:
you got a better picture of the second wire?
I can't see what colour it is, or where it is coming from. Large chance it should be an earth though from the myriad of wires around the dizzy.
Yer will get a pic tonight and post tomo prob still cant even find were the other connection is supposed to go looked all over engine bay :?
You will have to forgive me i am very much a novice and is my vw let alone a corrado.
Here is the other wire sorry took so long was busy cracking my windscreen :brickwall:DSCF0022.JPG[/attachment:2yhrj5yk]
Two green bad boys wrapped up and coming from behind the coil eh? Interesting.
I'll have a peek in the morning, see what I can find. :salute:
