KipVR
VR6 Hub Carriers
Are VR6 hub carriers the same as Mk 3 Golf VR/gti ones? I need a pair of Corrado VR6 ones preferably with bearings and wheel hubs still in them.
According to ETKA - if what I think you mean are hub carriers, ie the full verticle section that takes the driveshaft, and primary bearing, and off which hangs the hub:-
The 1995 Rado had two hub carriers. Part numbers:
- Left - 357 407 255 C
- Right - 367 407 256 C
The Golf 1995 had variations in its hub carriers:
- Left had 1H0 407 255C, 191 407 255C, and 357 407 255C
- Right had the 256C equivalents...
From the pictures, and a call to a friend who works in a VAG garage, it seems that there were two versions, one which was identical to the 'rado, hence the same number, and another which had a different caliper carrier mount (and was more common). His advice was to take photos of your one when you visit a breakers and check that the mounting points and hangers are the same as yours.
I hope that helps
