TomD
Quick Fuel Line Question....
Hi All!
Did some searching and trauling through the bentley manual but...no luck
Hopefully a very quick question that someone can clear up for me....
which fuel line is the one that brings the fuel to the fuel rail and which is the return? (The one that goes into the fuel pressure reg or the on that goes into the top of the fuel rail?)
I'm guessing the one that goes into the FPR but wanted to make 100% sure!
Thanks in advance!
Tom :D
Send (from tank to engine) goes straight into the fuel rail (just left of centre),
Return (from engine to tank) comes out of the underside of the fuel pressure regulator,
Fuel pressure switch is connected to the right end of the fuel rail by a U-bend of rubber hose.
Hope that helps :wink:
