rustyturret 0 Posted June 15, 2008 Hi all, 1st) I went to try and remove the front drive shaft/hub nut on my 1995 VR6 drive shaft earlier today and was suprised when none of my sockets fitted! It looks like a multi pointed nut not of the hexaganal variaty. Do I require a special socket (what size) for this job as I only have the comanal garden 6 sided variet? 2nd) I'm in the middle of changing most of the bushes on the motor and was wondering how to drop the sub frame enough to do the front anti roll bar ones. I have losened/removed the four at the rear of the frame and have searched other posts that say to losen the two front ones. For the life of me I can picture the ones they mean! And also sure the engine mounts power steering rack etc also bolt to the frame?? Any advice would be appreciated as the bently manual/haynes MK2 book of lies are about as much use as a chocolate tea pot :lol: Cheers in advance.... Quote Share this post Link to post Share on other sites
Supercharged 2 Posted June 15, 2008 Hub nut is a 12 point 30mm - you get one in the Halfords 150 Pce set. Quote Share this post Link to post Share on other sites
rustyturret 0 Posted June 15, 2008 Cheers I'll see if I can get hold of one tomorrow, so anyone got any ides on the sub frame issue? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted June 15, 2008 This might help - Quote Share this post Link to post Share on other sites
rustyturret 0 Posted June 15, 2008 So am I right in thinking that you have to losen/completely unbolt the two engine mounts and steering rack? It's what I thought when I was under the motor today but find it hard to believe you have to go through all that to replace two bushes! Quote Share this post Link to post Share on other sites
rustyturret 0 Posted June 15, 2008 Bump! Anyone done the ARB bush change in situ on the car as i really want to get stuck in to it tomorrow :? cheers.... Quote Share this post Link to post Share on other sites
millerman 0 Posted June 16, 2008 i have done it but its not an easy job undo the sub frame nuts at the front and rear and also undo the 2 nuts on the engine mount (near side/ passenger side) this will give you just enough room to play with (you may need to use some blocks to push the sub frame down a bit like i said its not an easy job to do in situ kel Quote Share this post Link to post Share on other sites
rustyturret 0 Posted June 16, 2008 Hi there, You're right it's not an easy job but just for anyone who Quote Share this post Link to post Share on other sites
rustyturret 0 Posted June 17, 2008 I'm not sure if they are avalible off the shelf as a polyethelene bushe but I have turned up some UHWMPE bushes to replace the rubber bush in the ARB link arm to stiffen things up a little!? They are super rigid and UHWMPE has excelent ware properties so should help things along :D Quote Share this post Link to post Share on other sites
