maturinvr6
Cooling problems
Recently after changing the bearings of the slave fan and with everything working perfectly before, this happened: The fans only work with the A/C on. First and second speed start as usual (I am using a 70oC thermo with 71oC fan switch). If I do not start the A/C the temperature goes to 230oF or our 110oC (my Corrado is an american SLC) and then starts the third speed. I already changed the fan switch and found that there is no current on the cables which connect it (there are three) I don't have the connector as it was to old and it broke. I suppose that two of those cables will have current all the time. The fan control unit was tested and works, the fuse No. 19 is OK. I don't know which relay I must check. What to do? :shrug:
:help: from Caracas
