tankybaby
Which base car?
Sorry if this has been asked before but if i wanted to build a 1.8 20vt corrado then which car should i start with?
I would be fitting coilovers and bigger brakes so would i be better off getting a cheaper valver leaving me more money to spend on the conversion or is it best to start with a higher power model such as a g60 or vr6? :confused4: :shrug:
4 Cylinder model, as the subframes will be right. I assume you'll change the suspension, brakes etc, so I'd go for the one with the best interior and exterior that you can find for the right price, g60 or 16v doesn't matter but I suspect that you're more likely to find a valver cheaper.
2.0 8V - late cars, 4 cyl but with some of the 'plus' running gear.
Most have no sunroof, so makes them a bit more rigid and gives more head room
