-Neil-
electrical woes, Big red wire going into windows fuse (pics)
when i put my drivers window down all the way, the fuse for the windows blows, i have checked for broken wires and cant see any, but when i put the fuse board back after replacing the fuse, i hear the motor in the rear drivers pannel click, as if it was getting power, the not, then getting it, then not etc...
so i pulled the fuse box down again and inspected the wires, after unraveling some leccy tape i found these two wires were connected but a tiny bit of tape like this...
could these be causing the window fuse to blow when the window is all the way down, i cant see how it might be connected, but thought i'd check!
