skinnyman9000
4x100 to 5x100 conversion
Whats needed?
I ask because i have a 1990 valver and my wheels that need fitting are 5x100 VR fitment. I was going to get some adapters, but at £150 plus shipping (and more wheel bolts) it might end up being cheaper to just convert the car to 5 stud.
So, whats needed?
Pretty much just the hubs on the front, and discs on he rear i think.
ugh... more than that.. I think that this list is reasonably definitive...
20 VR6 Lug Bolts
spare wheel?
VR6 rear Rotors
Front VR6 Brake lines
VR6 Sway Bar and End Links
VR6 Control Arms and bushings
VR6 Drive Shafts and bolts for tranny
VR6 Steering Knuckles
VR6 Bearings
VR6 Tie Rod Ends
VR6 Front Rotors
VR6 Spindles
VR6 Hubs
Man i was trying to inspire him with confidence but you just shot that out of the window...... :scratch:
Is that the list to just make it 5 x 100 or to make it widetrack too, dumb q i know
I think to do it right you have to go widetrack. ..
I was going to do the swap w/ the 16v, but time has gotten shorter for us in england.
20 VR6 Lug Bolts
spare wheel?
VR6 rear Rotors
VR6 Bearings
VR6 Tie Rod Ends
VR6 Front Rotors
VR6 Spindles
VR6 Hubs
wheel adapters it is then!!!
Question is though, am i going to be ok with 8's all round PLUS the width of the adapters? I guess i need to know the ET to know that, hmmmm
Carl (bigpants) quoted me a great price on this stuff, which I saddly have to pass on... give him a call, you might be surprised.
Its more of the time constraints now, on tues im on hols until 25th, and i need to get it sorted for E38
Well adapters wont work due to the offset of 36 on the wheels, so the fronts will be too wide, christ this is getting complicated. I might just sell them and buy some wheels that actually bloody fit!
sucks... we're leaving england early, and I bought a set of wheels for the corrado at home... trouble is that the wheels are brutally expensive to ship home so I was planning on installing them onto the 16V... hence the info for the bolt swap... I'm on the same boat, not enough time.
Yeah i'm getting confusious.
In regards to making it wide track your offset will be different. Not sure that with those parts listed that the rear would be different though ??
Those pics in the link that i posted make it look easy, obviously worked for him !
Bahn Brenner do a 5 stud conversion kit for G60's too.
