cardboard
vr6 cutting out when clutch ingaged
as i arrive at junctions and lights etc and put the clutch in the car decides to to just die. it also does it when starting i have to hold it at 1500rpm when i turn the key otherwise it just starts and then dies?
it doesnt do it all the time tho but a least a few times every journey?
i presume its a sensor on the way out? anyone solve this for me?
thanks
Use the search, luke!
Try ISV, MAF, lambda, crank sensor .. etc etc etc..
First port of call is an engine error code scan. The "stalling VR6" issue is a well common problem, with a million different potential causes.
