zak 0 Posted July 29, 2008 from the russian techincal site i got the below details Tightening torque, engine cold Tighten bolts in sequence: Stage I = 40 Nm (29 ft lb) Stage II = 60 Nm (43 ft lb) tighten in sequence additional 1/2 (180 ) turn further in one movement two additional 1/4 (90 ) turns are permissible I don't get the last bit where it says two additional 1/4 turns are permissable, does this mean i should carry out this last stage or not? Quote Share this post Link to post Share on other sites
zak 0 Posted July 29, 2008 heres the link to the document i got the settings from incase anyone is interested http://volkswagen.msk.ru/engine/aaa_pg/aaa_pg_cylinder_head_valve_drive.pdf Quote Share this post Link to post Share on other sites
Toad 0 Posted July 29, 2008 It means you can go for 1 x 180 degree turn or 2 x 90 degree turns. go for 2x90, it's fooking tight! Quote Share this post Link to post Share on other sites
zak 0 Posted July 29, 2008 okay now i read it again it makes sense. Quote Share this post Link to post Share on other sites
