Kempy
Running Rich??
I'm not really sure where to look to for this problem..I got a valver which I've changed both lift pump and electric pump under the car because they were in need of changing. Before the car went off the road it was very sluggish in 1st and 2nd gears and had very poor throttle performance. Now its not as bad, but still not like my other valver which runs perfectly. Could it be some tuning or timing problems? :shrug: As for fuelling, everything is good up to and including the distributing meter in the bay..
I'm asking really where to go to next? as I'm not sure what it could be
Cheers Kempy
Hi
What spec is the rado.
How do you know everything is good upto that point?
hia
It's a 2.0l 16. Only thing I'm going on is that I've replaced the pumps, filters and have had the pressure tested. But the pressure was tested before I changed the pump under the car, It was don 1 bar. Also the pressure in the metering unit seems fine but I'm no expert.
Any Ideas?
Running rich will show as sooty deposits on the spark plugs. A faulty Lambda can often cause the car to run rich. Worth checking.
what is running rich.. exactly I use the term but don't really know what it is :cuckoo: . I will check the plugs and lambda..cheers
Its when there is too much fuel being used. The car needs the correct air/fuel mixture. The lambda or CO2 sensor monitors it and the ECU adjusts the mixture. If the sensor is fubared the ECU can incorrectly increase the fuel ratio. Too little fuel is known as running lean. Running rich is also signified by black smoke out of the exhaust.
The exhaust is not blowing out black smoke. What would then be indicating it was running rich? Would the slow acceleration performance indicate this or would this indicate something else possibly?
