don_stavrou 0 Posted August 15, 2008 I have been reading here and there about people using the 1.8T 20v Inlet manifold on the 2.0 16v ..any ideas? Thanks Quote Share this post Link to post Share on other sites
Dec 1 Posted August 15, 2008 Haven't heard of that mod tbh! The 1.8T is a short runner manifold designed for forced induction. It wouldn't suit the 2.0L in na form at all, and would result in a performance drop. The long runners of the standard inlet mani are designed to cause a ram effect and generate a small amount of back pressure. Quote Share this post Link to post Share on other sites
don_stavrou 0 Posted August 15, 2008 im going 2.0 16vT so would it be benefitial? Quote Share this post Link to post Share on other sites
Dec 1 Posted August 15, 2008 ahhh! Yup, it would suit a 16vt :wink: I think it may need to be modified to fit the 9a....but don't quote me on that :razz: (referring to your other thread) It would be easiest to use the standard 1.8t fuel rail and fpr with that mani too. Quote Share this post Link to post Share on other sites
don_stavrou 0 Posted August 15, 2008 wiked thanks mate, me and ma mate jus relized its mechanical injection, so we gunna go for the 20vt inlet and fuel rail.. :D Quote Share this post Link to post Share on other sites
don_stavrou 0 Posted August 15, 2008 any ideas how easy it is to bolt on the 1.8T Injection system? Quote Share this post Link to post Share on other sites
Dec 1 Posted August 15, 2008 Not easy at all! :eek: It would be far easier to do a complete 1.8T 20v engine conversion! Or else use the likes of a Megasquirt ECU to control the EFI system and also control the standard 9a ignition system. Quote Share this post Link to post Share on other sites
don_stavrou 0 Posted August 15, 2008 ok get what u saying, im gunna be running standalone managment to control everything, so mechanically will they bolt on? Quote Share this post Link to post Share on other sites
Dec 1 Posted August 15, 2008 Yup, easy to do in that case. Just remove the entire orig airbox + metering head + fuel system. The 1.8T fuel rail + fpr, can then be hooked up to the fuel + return lines from the standard 9a fuel pump. You'll need some high pressure fuel hose and fittings to extend the hoses up to the fuel rail, but they are easily available through the likes of demontweeks etc. Quote Share this post Link to post Share on other sites
don_stavrou 0 Posted August 15, 2008 so basically any 1.8T (from the vw and audi range) inlet manifold and fuel rail will fit then? Quote Share this post Link to post Share on other sites
flusted 0 Posted August 15, 2008 you would need to cut the head flange off the 1.8t mani and weld on a 16v flange for it to fit. You can then use the 1.8T fuel rail and if using megasquirt, use whatever injectors you like Quote Share this post Link to post Share on other sites
don_stavrou 0 Posted August 15, 2008 ok thats fair enough is there any difference between the 1.8T inlets etc..or are they all the same? Quote Share this post Link to post Share on other sites
flusted 0 Posted August 15, 2008 some inlets are on the left, some on the right. I can get flipped long runner 16v inlets for £75 exchange. Im using 1 on my 16v g60 Quote Share this post Link to post Share on other sites
don_stavrou 0 Posted August 15, 2008 but appart from that, flow wise there the same? and size? Quote Share this post Link to post Share on other sites
