Spicy G60 0 Posted August 18, 2008 does anyone know how to change a power steering pump on a k reg G60 and how hard it is? I wanna change mine but don't know whats involved. Quote Share this post Link to post Share on other sites
Toad 0 Posted August 18, 2008 There are 2 pipe fittings into the pump and about 4 or 5 13mm bolts from all sorts of wonderous angles. Undo the pulley bolts before removing any belts then have a crack at the pipe fittings before working your way around the pulley to bracket bolts. There is one in particulat that it well hidden and needs a small socket and extension to reach. Main problem will be finding the right sized spanner for the pipe fittings. Think it's probably around a 24mm. Your PAS fluid will escape during this, so you'll need to bleed the pump according to instructions found on here. Quote Share this post Link to post Share on other sites
Spicy G60 0 Posted August 19, 2008 Cheers I'll try have a go this wknd if i get time. Thanks for your help. Quote Share this post Link to post Share on other sites
