be here now 0 Posted August 20, 2008 hi putting my g60 lump in a golf was sorting the wires out today came across these two wire blokes does ne one now were thay go think it might of been under the hand brake cover or near there ne 1 got ne clues to why for cus there just empty plugs pushed in the blokes Quote Share this post Link to post Share on other sites
BILLCOR 1 Posted August 20, 2008 Under the gear lever surround Quote Share this post Link to post Share on other sites
Riley 0 Posted August 20, 2008 The top one sits behind the center console on the rado's...its just a connector for the plugs that go in there. The bottom one sits under gear lever surround as said above. Neil. :) Quote Share this post Link to post Share on other sites
be here now 0 Posted August 20, 2008 sweet cheers u no what there used for Quote Share this post Link to post Share on other sites
waynos 0 Posted August 20, 2008 i thought they were used for diagnostics? Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted August 20, 2008 i thought they were used for diagnostics? bingo.... Quote Share this post Link to post Share on other sites
be here now 0 Posted August 20, 2008 cool so ill keep them near as poss to were thay come from then Quote Share this post Link to post Share on other sites
was8v 0 Posted August 21, 2008 They are for conencting diagnostics, e.g. VAG-COM to the OBD of the cars ECUs. However IIRC your G60s engine ECUs don't have any diagnostic function, only the ABS ECU has diagnostics in G60 cars. Since you have dropped the ABS in the transfer of stuff to the golf, the diagnostic connector will be of zero use to you. Quote Share this post Link to post Share on other sites
paul20v 0 Posted August 23, 2008 the black and white ones are for diagnostic as they are with many v.a.g. cars but what are the other ones that go behind the console for? Quote Share this post Link to post Share on other sites
was8v 0 Posted August 23, 2008 the black and white ones are for diagnostic as they are with many v.a.g. cars but what are the other ones that go behind the console for? On some corrados theres the wires for the optional gauges (oil pressure and voltage) in place. Quote Share this post Link to post Share on other sites
