awigman 0 Posted August 24, 2008 I recentrly bought a 96 plate Polo 1.6 to use as a daily runner while i sort my C out, the problem now is it wont bloody start. It cut out as i was driving and when i try to start it, it just whines. Any ideas what this could be, i know nothing about polos so im stuck. could it be the starter? i would really appriate any help!! Quote Share this post Link to post Share on other sites
horney 0 Posted August 24, 2008 A starter wouldn't really cause it to cut out. When you say it whines, does it actually turn over? Nick Quote Share this post Link to post Share on other sites
awigman 0 Posted August 24, 2008 it dosnt turn over just makes a noice like its trying to turn over.Sorry its really hard to explain Quote Share this post Link to post Share on other sites
mattkh 0 Posted August 24, 2008 Hi Take the starter out, give it a good clean, test it and then put it back in. Quote Share this post Link to post Share on other sites
red-rado 0 Posted August 24, 2008 Does it start when you bump start it? Quote Share this post Link to post Share on other sites
awigman 0 Posted August 25, 2008 nope it dosn't start when i try to bump it. Quote Share this post Link to post Share on other sites
mattkh 0 Posted August 25, 2008 nope it dosn't start when i try to bump it. Hi Can you turn the engine over by hand ? Quote Share this post Link to post Share on other sites
rodenal 0 Posted August 25, 2008 Don't wanna scare you but have you had a look at the timing belt? Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted August 25, 2008 Don't wanna scare you but have you had a look at the timing belt? bang on,take off the oil cap (if you can see the cam) is it turning as you crank? Quote Share this post Link to post Share on other sites
awigman 0 Posted August 25, 2008 nope it dosn't start when i try to bump it. Hi Can you turn the engine over by hand ? how do you turn the engine over by hand? Don't wanna scare you but have you had a look at the timing belt? bang on,take off the oil cap (if you can see the cam) is it turning as you crank? sorry not very mechanically minded is the timing belt a big job? the car has only done 50 000 miles is it likly to be this? thanks Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted August 25, 2008 regardles of the milage the cambelt can snap at anytime,the cam belt keeps the valves intime with the stroke of the pistons hence 4 stroke. changing the belt is not a bog job but when the belt snaps,99% of the time you will have bent valves,is it snapped? can you pull the camcover off and see if the belt is on? Quote Share this post Link to post Share on other sites
mattkh 0 Posted August 25, 2008 how do you turn the engine over by hand? Hi Car in neutral, wear gloves and then pull the 'fan' belt. Quote Share this post Link to post Share on other sites
awigman 0 Posted December 10, 2008 regardles of the milage the cambelt can snap at anytime,the cam belt keeps the valves intime with the stroke of the pistons hence 4 stroke. changing the belt is not a bog job but when the belt snaps,99% of the time you will have bent valves,is it snapped? can you pull the camcover off and see if the belt is on? Bang on..... After sitting on my parents drive for nealy 5 months i managed to get it to the garage for them to have a look, As suggested above the cam belt had snapped, bending the valves. Iv been quoted over a grand to get it fixed so there goes my daily driver. Anyone fancy a F*****D polo??? Quote Share this post Link to post Share on other sites
mattkh 0 Posted December 11, 2008 Hi Get a quote for swapping the engine over with one from the polo forum or scarppies. Quote Share this post Link to post Share on other sites
Jim 2 Posted December 11, 2008 Job #1 whenever buying a new car.. get the timing belt changed! Sorry to hear you've gotten screwed on it mate - sucks when your daily blows up worse than the Corrado! :( Quote Share this post Link to post Share on other sites
