peppyuk 0 Posted September 1, 2008 My VR has had an intake air temp sensor fault since I've had it and last week I got a replacement from GSF. After fitting, the rad fans come on a few seconds after start up and stay on while it's running :scratch: Anyone know how or why this would bring the rad fans on? TIA Quote Share this post Link to post Share on other sites
Toad 0 Posted September 1, 2008 Think you've got the black temp sensor and the inlet air temp sensor plugged in back to front. Quote Share this post Link to post Share on other sites
peppyuk 0 Posted September 1, 2008 The rad fans have always seemed to have worked fine (had the car over a year), and they seem to be working ok now I have the faulty intake temp sensor back in. How would I check that everything is connected as it should be? Quote Share this post Link to post Share on other sites
Toad 0 Posted September 1, 2008 The connector to the black temp sender is seperate to the yellow and blue wires, and runs down the front of the engine and into the fan wiring loom. The air intake temp sensor connector is bundled with the yellow and blue temp sensors. Quote Share this post Link to post Share on other sites
peppyuk 0 Posted September 1, 2008 I've had a look but it looks like someones been here before and all the wires are together, anyone willing to have a look and see what colour wires go to what? Quote Share this post Link to post Share on other sites
Toad 0 Posted September 1, 2008 I'm more than happy to once I've returned from Germany... Quote Share this post Link to post Share on other sites
peppyuk 0 Posted September 1, 2008 Well, I've been having a poke about (as you do on dark wet nights) and swapped the 2 plugs over and let the engine run for a little while. It would seem I now have a multi speed fan! Having spoken to a friend whos had a couple of Corrados this is right, god only knows how it was working with them back to front. Thanks for the help. Quote Share this post Link to post Share on other sites
