g20_2004 0 Posted October 3, 2008 Any ideas of the prob???????? 92 corrado g60 with CAT, standard car and standard boost. my emissions readings fast idle test: engine speed: 2450-2850 rpm 2531 rpm pass co: hc: lambda: 0.970-1.030 0.861 fail second fast idle test: engine speed: 2450-2850rpm 2529rpm pass Co: Hc: lambda: 0.970-1.030 0.832 fail natural idle test: Engine speed: 700-900rpm 863 pass co: Overall result FAIL Quote Share this post Link to post Share on other sites
Valerian 0 Posted October 3, 2008 You may either have to fit a new lambda/o2 sensor or a new cat. Try the sensor first. Surprised your MOT tester couldn't offer more help. Quote Share this post Link to post Share on other sites
g20_2004 0 Posted October 3, 2008 he didnt hav much of a clue bud. Quote Share this post Link to post Share on other sites
dirtytorque 0 Posted October 3, 2008 he shouldn't be giving you a fast idle test anyway. :scratch: Any MOT experts to confirm or deny??? Quote Share this post Link to post Share on other sites
Super-G 0 Posted October 8, 2008 he shouldn't be giving you a fast idle test anyway. :scratch: Any MOT experts to confirm or deny??? Depends what month in 1992 it was first registered, as to whether it has to have a cat test. But the CO does look well high. What's the resistance of the CO pot? Quote Share this post Link to post Share on other sites
chez2165 0 Posted October 9, 2008 I had the same problem when my car had its MOT turned out it was the wires that went to the lamda sensor so it would be worthwhile trying that first. Quote Share this post Link to post Share on other sites
peteTDI 0 Posted October 9, 2008 if its on a K plate you need a new lambda sensor looks like its stuck on rich if its on a J plate slap the tester as he/she should be doing a non-cat test Quote Share this post Link to post Share on other sites
Yandards 0 Posted October 10, 2008 if its on a K plate you need a new lambda sensor looks like its stuck on rich if its on a J plate slap the tester as he/she should be doing a non-cat test I think a lot of tester just do the CAT test if there is one fitted, a little lazy though. Quote Share this post Link to post Share on other sites
flusted 0 Posted October 10, 2008 I just got mine through by adjusting the co pot, mine has no cat though Quote Share this post Link to post Share on other sites
