Dude VR6
Eletric Window
Hi
I`m having a problem with my drivers window. Its stopped working, you can still hear the motor working but there is no movement in the window.
Is this a common fault ? I think that the regualer is jammed and stopping the window from working. I had a quick look yesterday but soon gave up as I couldn`t be ased. Any idea`s ?
If the motor in that same door is running but the window is not moving then a drive cable has probably snapped.
Usually if the window cannot move because of an obstacle the fuse will blow.
So from what you describe i'de say snapped cable.
