Merstham_VR6
Short Shift...
I'm pretty sure these are 50% reduction, which I personally think is a little too much for the cable change system, it's basically a cut and re-welded standard part moving the pivot point. I looked into doing this with a cut and re-welded passat lever which I fixed in position without having actually cut the bottom part to fit the cable, it would give a 25-30% reduction which I reckon would be a better compromise.
