coullstar
Rear ABS ring position??
Does anyone have an exploded diagram of the rear set up on a VR specifically showing the position of the rear ABS ring.
Its been a long time since Ive looked at rear brakes.
I have 15mm spacers on the rear that Im taking off and replacing with 5mm but have to use the 15mm longer bolts. I dont want to put them on and damage the ABS rings ya see.
Mmmm, just as I though it seems to sit round where the bearing sits. Hopefully there a bit of clearance for the bolts.
Thanks.
Shouldn't have a problem with longer bolts there, I've just pulled out one of my rear discs and the ABS cage actually shys away from the bolt holes if that makes sense? Should have clearance for another 15mm of thread.
