SamG40 0 Posted November 6, 2008 Evening, can anyone please tell me what they see for the values on VAGCOM for a healthy lambda probe please? I've been getting a Lambda fault code and I had a failure on the MOT for emissions. It only cycles between 0.95 and 1.04 or so which to me dosent seem to be correct. I've done a search and cant really find a defintive answer. The emissions failure was the CO2 level was 0.98 by the way with the limit being 0.30. Apparently it was fluctuating up and down. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted November 7, 2008 The lambda cycling between 0.95 and 1.04 is about right actually. What's the fault code? Quote Share this post Link to post Share on other sites
SamG40 0 Posted November 7, 2008 I cant remember the exact error but it was something along the lines of the lambda value out of range and being intermittent. Surely the voltage should cycle to a lower voltage on idle. I was always led to believe that Lambda's read between 0 and 1 volts?! Quote Share this post Link to post Share on other sites
dr_mat 0 Posted November 7, 2008 Yes, but the VAGCOM value isn't volts, it's lambda.. The fact that the error is "intermittent" confirms to me that while you're reading it it's fine - 0.95-1.05 is right. I guess you either have to replace it anyway, or keep reading the values until you see something that's genuinely bogus. Quote Share this post Link to post Share on other sites
SamG40 0 Posted November 7, 2008 Ah right, cheers for that. Well I replaced it last night. Will keep an eye on it. If it isnt this that is causing my emissions though I'm a bit stumped. The car is running fine but the fuel consumption has been well down on what it used to be. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted November 7, 2008 Look for air leaks, anywhere between the MAF and the lambda will cause mixture problems. Quote Share this post Link to post Share on other sites
SamG40 0 Posted November 7, 2008 Woohoo. Seems it must have been the Lambda. I've just got back from the MOT and it passed with a CO reading of 0 and a HC reading of 7ppm which now seems incredibly low! Quote Share this post Link to post Share on other sites
dr_mat 0 Posted November 8, 2008 Yup, sounds like it! Quote Share this post Link to post Share on other sites
Toad 0 Posted November 8, 2008 :) Isn't the lambda set to show 1 at an air/fuel ratio of 14.7? Quote Share this post Link to post Share on other sites
dr_mat 0 Posted November 8, 2008 Yep, think so, 1 == stoichiometric a/f mix. Quote Share this post Link to post Share on other sites
