timthetinyhorse 0 Posted November 10, 2008 as the tital says i realy need some diagrams/drawings of oil system on 9A engine as need to start pulling it to bits to sort a leak out, if anyone has any drawings/has auto data and wouldnt mind helping me out i would realy appreciate it, also if anyone knows if the engine has an oil cooler this may help as im strugling to work out what the corroded pipe thats causing on of the leaks does/is there for cheers rob Quote Share this post Link to post Share on other sites
davidwort 0 Posted November 10, 2008 like most VAG 4cyl engines it has an oil/water heat exchanger mounted immediately above the oil filter, two hoses from the water system connect to it. If this perforates inside you somtimes get symptom similar to a head gasket failure, oil in water etc. The oil system is pretty straightforward, oil pump driven by intermediate shaft, pickup filter in bottom of sump can get blocked in badly maintained engines, generally a very reliable system. Quote Share this post Link to post Share on other sites
timthetinyhorse 0 Posted November 11, 2008 cheers mate, will have a look this weekend, the oil is coming from the area you mention so will check the condition of the pipework this weekend Quote Share this post Link to post Share on other sites
