Jay2
How do I run a G60 without a Supercharger?
How do I disconnect the Supercharger on a G60 to run the car without it?
Got a weird noise in the engine bay and wanting to run the car temporarily without the Supercharger to see if it makes a difference to the noise.
Do I just disconnect everything or is it more complicated than that? :shrug:
I think your problem has been answered in the other post, but just incase this is different (or i'm going mad and think you are someone else) have you tried a listening stick? any solid metal stick will do, just press it against the area the noise is coming from and it will amplify the vibrations and help pinpoint the problem. But if you are the person from the other thread (please be, so i can prove to myself i'm not :cuckoo:) then it sounds like a boost pipe has popped off or split.
HTH
