davidvw
Corrado spring caps???
Hi all, my corrado vr6 has got full koni adjustible suspension setup, i think its lowered bout 40mm
the problem i have is the back shocks are on the lowest setting which looks slightly lower than the front
was thinking bout getting some lowered spring caps to level it up..
Are they any good? will they do the trick?? Any advice worth getting?? or steer clear?? cheers... :wave: :wave:
they do work as they say on the tin, but im having issues with them clunking when steering when parking etc as i think they are binding on the rubber top mount. dont think its anything to worry about but its a bit annoying, not sure ill be leaving mine in, but cant find any suitable 60mm springs at the mo!
careful on what ones you get as theres 3 differnet types- youll probably need the early VR6 type which are 105mm diameter.
