jonnyoutram 0 Posted November 21, 2008 any ideas? i sould not find anything in the search?? the car has had some chavvy lights put behind the dash! could something have come dis connected or broken? whats the usual suspect? any ideas of what to search for in the knowlage base? :help: thanks :help: Quote Share this post Link to post Share on other sites
coolrado 0 Posted November 21, 2008 sounds like the signal wire from the ignition is disconnected so the MFA thinks the ignition is off and just displays the time. Quote Share this post Link to post Share on other sites
jonnyoutram 0 Posted November 21, 2008 where do i find this signal wire? :confused4: Quote Share this post Link to post Share on other sites
ninoG60 0 Posted November 22, 2008 yeah where is this wire as i have a very similar issue Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted November 22, 2008 follow the mfa stalk,should be a this multiwire with a white multiplg attached to the colum. Quote Share this post Link to post Share on other sites
sparks 0 Posted November 27, 2008 yeah im guessing at the plug hasnt been reconnected too its right hand side about 3 inches into the dash on the steering column Quote Share this post Link to post Share on other sites
