benbudunen
g60 map sensor upgrade
Can someone help about upgrading g60 map sensor to 250kpa.
250kpa sensor is different looking than old one.
So how can I know which pins i solder to ecu?
250kpa.jpg?t=1228070706
You will obviously need a remap straight after its fitted.
Surely you would be better off making sure the engine flows better before fitting 1 of these?
