phayeser 0 Posted December 9, 2008 Hi there, so my rocker/valve cover gasket is leaking and wants replacing. Would this be a big job? Really have no idea. What other gasket should I order for the job? And where is a good place to get gaskets? My thanks Quote Share this post Link to post Share on other sites
horney 0 Posted December 9, 2008 Which engine? Nick Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 9, 2008 Hello, you need to take the inlet manifold off to do this or at least the upper part of it so you need new gaskets for this too and the throttle body, I would also buy new bolts too if they look corroded. Get the bits from VW to avoids getting parts that don't fit. Quote Share this post Link to post Share on other sites
speedysmartypants 0 Posted December 9, 2008 its an easy job even for a novice. dont use a victor reinz gasket. mine started leaking after a day. buy cheap, buy twice! get it from VW Quote Share this post Link to post Share on other sites
phayeser 0 Posted December 9, 2008 thank fellas Quote Share this post Link to post Share on other sites
Conker 0 Posted August 24, 2011 Hi, Thought I would use an old thread rather than starting a new one... I'm replacing the rocker cover gasket (plastic covered VR6 one) and just thought I would check something. On the rocker cover there is a small plastic tab on the airbox side of the head that sticks down over the half-moon rubber bung thing that covers the cam hole. Does this tab need to push into the half-moon bung (i.e. pushing it down, which feels too tight), or should it sit next to the half-moon (which doesn't seem to align up very well, pushing the half-moon inwards slightly)? I would go with the latter, but thought someone on here would know for definite! Lastly, is using instant-gasket definitely advised, as my old Mk2 golf seemed to leak less without sealant? Cheers all, David Quote Share this post Link to post Share on other sites
Conker 0 Posted August 24, 2011 This is the bit I mean... you can see the tab above the half-moon rubber bit... Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted August 24, 2011 i would think the tab sits to the side of the half moon,also only put sealer is the corners of the gasket..your don't need it anywhere else . Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted August 25, 2011 This may seem obvious, but.......... The gasket has steel washers in it where it goes over the studs. Make sure that you remove the washers with the old gasket (i.e. don't leave them behind) otherwise the gasket will not seat properly. It shouldn't need any sealant if you carefully clean both machined surfaces. Don't over-tighten the nuts. DO tighten the nuts as you would a cylinder head, that is to say working from the middle outwards and in a progressive way. One or two of the manifold screws will be rather inaccessible and can be quite tight, being steel into aluminium. I found it easier if you release the front engine mounting and jack the engine up a little to give more clearance over the slam panel. If you get new manifold screws from VAG, make sure that you also get new washers; you can't get the washers off of the old screws! Make sure that you stuff rags or paper temporarily into the lower inlet manifold stubs and drape a cloth over the cams and chain whilst working with the cam cover off; you don't want to go dropping bits and pieces down into the bowels of the engine. Best wishes RB Quote Share this post Link to post Share on other sites
Conker 0 Posted August 25, 2011 This may seem obvious, but.......... The gasket has steel washers in it where it goes over the studs. Cheers RB, all helpful. But the studs bit... Isn't that on a metal rocker cover only? Mine has bolts through the rocker cover itself (unless I've misunderstood you). As for clearance - thats not problem as the whole front of the car is off :-) (This is part of a head gasket rennovation). Quote Share this post Link to post Share on other sites
Rocket Ron 1 Posted January 9, 2016 (edited) Started dismantling mine today will let know how it goes gaskets Cover, manifold and throttle on order. I fancy cleaning up manifold what about painting and paint type.Should it be heat resistant. Anything I should be looking out for. Edited January 9, 2016 by Rocket Ron Quote Share this post Link to post Share on other sites
Jim 2 Posted January 9, 2016 Hi Ron - I think you may struggle to source a throttle body gasket - was told these are now obsolete by VW. In terms of the manifold, I had mine media blasted back to bare metal which I think looks great - nice and clean. As yours isn't a daily I'd say you don't necessarily need to consider painting, but a high temperature engine paint such as this would probably be best for some durability: http://www.halfords.com/motoring/paints-body-repair/specialist-decorative-paints/halfords-very-high-temperature-aluminium-paint-300ml Would need to be heat resistant really because of the amount of heat soak from the engine. Might also be worth whipping your injectors out and getting them refurbished? Once the upper manifold is off, it's not a huge amount more work to remove the fuel rail to be honest :) If you decide to replace other nuts and bolts used around the manifold, the covers, etc - all the rest of them seem to be available from VW no problems and not crazy money. Quote Share this post Link to post Share on other sites
Rocket Ron 1 Posted January 9, 2016 Cheers Jim for advice With the injectors where should I have them done and rough cost. Ron Quote Share this post Link to post Share on other sites
seanl82 23 Posted January 9, 2016 MrInjector can refurbish your set, they'll do before and after flow tests, paint them and provide new seals for around £75 iirc but give them a call. You can get some gasket paper for the throttle body gasket Ron. Just trace out your old one onto the paper then cut it yourself. Easy and cheap to do if you can find somewhere local to buy it and match the thickness of your old one. (Obviously go slightly larger as the old one will have compressed a fair bit over time). Quote Share this post Link to post Share on other sites
16VG60 1 Posted January 10, 2016 Hi Ron, have been reading through this post. We (JMR) can clean your fuel injectors as we have been providing this service since the days when we used to see you at our workshops. With regard to your can cover we can powder coat this for you and this would be the most durable finish possible. Give us a call, would be good to hear from you Quote Share this post Link to post Share on other sites
Rocket Ron 1 Posted January 11, 2016 John Thanks for that roughly how much for cleaning injectors and powder coating or would you rather I called. Ron Quote Share this post Link to post Share on other sites
Rocket Ron 1 Posted January 12, 2016 Got to make a decision now do I or don't I get my injectors cleaned while I have my valve cover and manifold off. VR has done 113k and fuel filter is changed as per maintenance schedule. Would it make a difference as there is nothing wrong at the moment co and MPG is good. Cheers Jim for advise got paint and it looks good. Quote Share this post Link to post Share on other sites
16VG60 1 Posted January 12, 2016 Hi Ron, give me a call tomorrow as am unable to talk just now. I look forward to hearing from you. Quote Share this post Link to post Share on other sites
Rocket Ron 1 Posted January 13, 2016 (edited) After talking to John at JMR injectors were successfully removed tonight and are ready for cleaning. All I need to do now is degrease the area so it is clean for putting back together. Edited January 13, 2016 by Rocket Ron Quote Share this post Link to post Share on other sites
massbad69 10 Posted January 14, 2016 http://www.arz-tuning.de/shop/product_info.php/info/p12170_Throttle-Body-Gasket---VW-VR6-2-8-2-9-Engine-AAA-ABV.html Throttle body gasket Quote Share this post Link to post Share on other sites
Rocket Ron 1 Posted January 15, 2016 Thanks for the link very useful ordering one today. Injectors now being refurbished. Quote Share this post Link to post Share on other sites
seanl82 23 Posted January 15, 2016 Worth adding a few other bits that they sell too to justify the shipping cost Ron, as they come from Germany. Thats what I did anyway as shipping isn't cheap! They do have some extremely hard to get hold of parts though that simply aren't available in the UK anymore. Quote Share this post Link to post Share on other sites
Rocket Ron 1 Posted January 16, 2016 Yes did that as well Quote Share this post Link to post Share on other sites
Rocket Ron 1 Posted January 17, 2016 Need some advice in process of putting VR back together after removing valve cover to renew gasket. Been given a Victor Reinz one but heard not very good. Any advice would be welcome. Thanks in advance Quote Share this post Link to post Share on other sites
