Toad
VR6 cam specifications
Does anyone have the specs for VR cams, specifically, standard, schimmel 263 and shrick 268 please?
I need to know inlet opening and closing degrees, inlet lift, exhaust opening and closing degrees and exhaust lift.
Thanks!
I've found some things out.
Standard cams, 10.2mm lift, 240 degree duration. Need opening/closing degrees for inlet and exhaust.
Schimmel cams, 11.4mm lift, 263 degree duration, 115 degree lobe centres. need at least one valve opening point to work out the rest of the information.
Shrick cams, 11.4 mm lift, 268 degree duration, 115 degree lobe centres. Again, I need at least one valv opening (or closing point) to work out the rest of the information I need.
Anyone able to help out? Or even point out that I have something wrong. Lol
