weetos 0 Posted December 17, 2008 Hi all well i've been getting an intermitent missfire for quite some time now all the usuall stuff checked vac pipes, filter, leads dissy, coil, rotor arm etc. The past week ive noticed the rev counter going a bit wild too. :? Then today she broke down, loads of clicking from fusebox same rev counter going wild, backfired if i went to wot. She would turn over but not start when going to ignition on i could hear the fuel pump but didn't sound normal. after a bit of poking around the fusebox found out relay 32 was quite hot un pulgged it, contacts looked clean so stuffed it back in and she fired up no problem but still having random missfires. so found out that realy 32 is digifant control relay. what does this actually control? does it just send power to ecu? :scratch: think it may be loose wires behind box , it's too cold and dark at the mo so just wondered what you guys thought. Quote Share this post Link to post Share on other sites
weetos 0 Posted December 17, 2008 Bump where is Yanards when u need him? Quote Share this post Link to post Share on other sites
Kempy 0 Posted December 17, 2008 give him a pm Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 18, 2008 He's in a very hot and sandy place! Yep, thats the ECU power relay, worth getting a new one along with a fuel pump relay and ignition switch if those 3 havn't been done (just for future reliability...) Quote Share this post Link to post Share on other sites
weetos 0 Posted December 19, 2008 He's in a very hot and sandy place! Yep, thats the ECU power relay, worth getting a new one along with a fuel pump relay and ignition switch if those 3 havn't been done (just for future reliability...) Ta for advice Supercharged will post when i find out what it is Quote Share this post Link to post Share on other sites
weetos 0 Posted December 30, 2008 Bit of an update It was the digifant control relay that was at fault, replaced and all is now good :D Quote Share this post Link to post Share on other sites
stevelibs 0 Posted October 31, 2009 Great Thanks for that guys Quote Share this post Link to post Share on other sites
