Rocket Ron 1 Posted December 23, 2008 Anyone changed Wishbones and balljoints and associated parts before looking for step by step guide. Only want to use OEM parts so been to VW for quote on parts looks like about £ 150 each side. Quote Share this post Link to post Share on other sites
herisites 0 Posted December 23, 2008 It's a pretty easy job mate considering you don't snap any bolts etc. It's all fairly self explanatory once you start it can just be a bit lengthy that's all. It's always a good idea to get some PlusGas or equivilent release oil/WD40 and spray all nuts/bolts that you will be removing leading up to when you do the job, should help things come undone a bit easier! Long bars for leverage are handy as well as proper tools like ball joints splitters, other than that just undo bolts holding things on! Quote Share this post Link to post Share on other sites
stevef182 0 Posted December 23, 2008 that sounds a bit pricey to me..but either way it should be fairly straight forward..however if you snap any bolts then it will become a very tricky job! happened to a friend of mine and was a nightmare! Quote Share this post Link to post Share on other sites
