vw domo
mystery pipe!
does anyone, know what this is. (outlined in red if you can see it) i was told it was a exhaust recirculation valve pipe and couldnt find anythin on the search. the bung on the end split so i was just going to block up the hole with a bolt and washer at the manifold. good idea???
Picture 063.1.jpg[/attachment:1e7kuq5y]
cool, will get onto that then. thanx. about to take a drive up to london and it seems to be blowing a fair amount which isnt good for the back-pressure i guess. the thread size on there isnt standard, m12 x 1mm pitch thread so im guna have to weld up the pipe unfortunatly. the MOT station will have to go sniff somewhere else :lol:
dont think the MOT man uses that, he'll just stick the probe up the tail pipe. The CO sniffer pipe is for when your tuning the engine to give a specific CO reading (ie not running too rich/lean) as it gives you a reading before the cat.
Just buy a new bung from VW...
Had this go on one of my old valvers- makes the engine sound a bit more fruity!
