rawtor51 0 Posted January 1, 2009 its a 1.8 KR engine, it sits beneath the injector pipes and just in front of the rocker cover. its got one wire connected to it with a crimp, please excuse the rubbish drawing :lol: but thats kinda what it looks like, the connection on mine is loose and i was gonna replace it, is there a certain one i would need to buy, i was looking on GSF's website but im not sure what to get. if it was broken what symptoms would i get as everything seems to be fine. any help is appreciated, Ross. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted January 1, 2009 i think what you are describing is the ambiant air temp sensor,it switches on the fan when there is to much heat under bonnet when the ingnition is turned off. Cant see it being much use in the UK.... Quote Share this post Link to post Share on other sites
Toad 0 Posted January 1, 2009 It's a temp sensor, for the run on fan on the 16vs I believe. I can't quite make your picture out properly though. Quote Share this post Link to post Share on other sites
rawtor51 0 Posted January 1, 2009 thanks lads , what would happen if it was dammaged. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted January 1, 2009 nothing.... :lol: Quote Share this post Link to post Share on other sites
Toad 0 Posted January 1, 2009 nothing.... :lol: :lol: If your under bonnet temperature is too high, it switches the fan on. (try earthing the wire to it to see what happens) The idea is that it keeps the fuel lines cool, so the fuel doesn't vapourise and cause starting issues. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted January 1, 2009 in the cold uk climate i suspect nothing would happen....but on my old 5 turbo it was a major problem! :( Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted January 1, 2009 My fan runs on lots so it may be worth changing if yours doesn't. Quote Share this post Link to post Share on other sites
rawtor51 0 Posted January 1, 2009 thanks very much lads , will have a look into it. Quote Share this post Link to post Share on other sites
