sim0n_parker 0 Posted January 1, 2009 right, ive searchd through the forum but it brings up tooooo many pages about abf lumps etc and i cudnt find a definet answer to my question. i have a 2l 16v corrado, on a 1991 J plate, im after the ABF engine to go into the car as i like the engines, i want to run it on the abf managment, does it plug and play into the back of the corrados fusebox? or is there major wiring to sort out, chears also any other fittting issues from people who have done it? Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted January 5, 2009 You may have to fettle the bonnet because the ABF engine is 15mm taller than the other 16V engines. I can't answer your question on the engine management wiring but someone else will be sure to help you. Best wishes and Happy New Year RB Quote Share this post Link to post Share on other sites
dirtytorque 0 Posted January 5, 2009 my car is on a J plate and I have the later bonnet which allows for a bit more clearance. Quote Share this post Link to post Share on other sites
flusted 0 Posted January 5, 2009 loom is plug n play, engine should bolt straight in, although i wouldnt want to use the abf mangement if it were me Quote Share this post Link to post Share on other sites
Lufbramatt 0 Posted January 5, 2009 done this conversion on my passat. loom plugs straight in, although depending on what you do with the imobiliser you might have to solder one or two wires to power the immobiliser box, and put a number 30 relay in the right place in the fusebox to power the ECU. Also you might have to use the rear engine mount bracket off your 9a lump as the ABF uses a VR6 style subframe with the "swiss roll" rear engine mount. Im using the Digi 3.2 management and it runs great with my P+P'ed cylinder head. 42+ mpg on the motoway too. I got a whole car and used the entire ignition housing and barrel from the donor car so I could keep the chipped key and transponder coil for the immobiliser working as VW intended- at some point ill re-tumble the door locks to match the ignition key but no rush. If you use the digi loom and ecu, make sure you check all the loom over and repair any dogy wiring- especially where the loom goes behind the intake mani as the wiring for the TPS gets a bit flakey over time. Also the wiring for the crank position sensor gets crusty and may need renewing. Quote Share this post Link to post Share on other sites
Brombey 0 Posted January 6, 2009 Not sure it's plug and play. Doesn't the 9A have a K-Jet type injection system with a high pressure fuel pump/seperate lift pump etc. Not sure how the electricals would match up to the digifant ABF. Quote Share this post Link to post Share on other sites
flusted 0 Posted January 7, 2009 thats seperate from the engine loom, and the pressures wouldnt matter. Quote Share this post Link to post Share on other sites
