bosshogg 0 Posted January 2, 2009 Changed rear wheel and whilst doin up the wheel bolts three of em wont tighten up, so can i get them recoiled as i only fitted new rear discs last year or ? any help much appreciated :pale: Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 2, 2009 Bit worrying- what brand of disk?? Sure the wheel bolts are not too long? I would get a thread restoring kit to clean the threads with (M12x1.5mm for 4 Stud) or replace the bolts New disc will be way cheaper than helicoiling - even after new bearings etc Quote Share this post Link to post Share on other sites
bosshogg 0 Posted January 2, 2009 thanx ,disc where drilled type £130 a pr cant be bought indervidual guess theres no cheap way out Quote Share this post Link to post Share on other sites
bosshogg 0 Posted January 4, 2009 UPDATE I decided to fit standard rear disc and bearings to get over problem. re thread the disc wheel bolt holes is probebly not a safe option :shock: Quote Share this post Link to post Share on other sites
Toad 0 Posted January 4, 2009 I suppose if you make sure you put the locking wheel bolt in that hole, then you'll minimise risks. But still. Quote Share this post Link to post Share on other sites
