vwdeviant
ABS rings
Anyone know if I can use a Mk3 Goof ABS ring on the front of my 16v?
Had a bent ABS ring which when straightened seems to have sent the ABS into a complete spazz, so having to run disconnected ATM.. mate has a spare mk3 ring that was removed from a new hub for a customer...
www.vagcat.com says yes - I cross referenced the ABS ring for the valvers against the ABS ring for the mk3 Golf (I went for 94 models on both), and as long as the Golf is 4-stud then yes it will fit.
