Andy665 0 Posted January 9, 2009 If you mean how tight the belt should be I used to work on the principle of it being fine if I could twist it through 90 degrees using a reasonable amount of effort - never had a problem Quote Share this post Link to post Share on other sites
weetos 0 Posted January 9, 2009 If you mean how tight the belt should be I used to work on the principle of it being fine if I could twist it through 90 degrees using a reasonable amount of effort - never had a problem sorry should of said whats the torque of the pulley bolt? Quote Share this post Link to post Share on other sites
