cvw74 0 Posted January 12, 2009 help needed on total height of tire and wheel. at the mo running winters - 6.5 x 15 with 205/55 rubber. trying to decide on summers at mo if i run a 9x16 with 205/40 or 215/35 also 8.5x17 with 205/40 would there be much difference in heights? thanks Quote Share this post Link to post Share on other sites
Leonard 0 Posted January 12, 2009 I could be wrong but I would have thought a 45 section tyre would be a better height on the 16's Quote Share this post Link to post Share on other sites
corozin 0 Posted January 12, 2009 If you run 40 profile on 16" wheels your car will be undergeared. Good for acceleration, but bad for fuel economy plus your speedo will underead your speed by around 4% Quote Share this post Link to post Share on other sites
cvw74 0 Posted January 12, 2009 corozin said: If you run 40 profile on 16" wheels your car will be undergeared. Good for acceleration, but bad for fuel economy plus your speedo will underead your speed by around 4% not thought about all that, on a 9x16 whats the best to run, as to be low though. As much as i want 16's may be better option to go 8.5x17 sump may be safer as well Quote Share this post Link to post Share on other sites
Leonard 0 Posted January 12, 2009 If you go for a 45 section on a 16 inch wheel it shouldnt be any lower than a std wheel. I think 8.5's would be on the wide side as wellespecially in 17 inch Quote Share this post Link to post Share on other sites
Rathion 0 Posted January 12, 2009 My workings make it the 15inch wheel with the 205/55 rubber should be 303.25mm to wheel centre. The 16inch wheel with 205/40 rubber should be 285.2mm to wheel centre. The 16inch wheel with 215/35 rubber should be 278.45mm to wheel centre. The 17inch wheel with 205/40 rubber should be 298.1mm to wheel centre. Hope my calcs are right and hope this helps. Quote Share this post Link to post Share on other sites
corozin 0 Posted January 13, 2009 I ran 205/40/17 on 8J rims on an old Corrado. With an 8" rim a 205 section tyre will give you a fairly decent stretch already, but the car should drive well. I would personally not go as wide as 8½" as I would worry about overstretching them and compromising safety. An 8½" rim is correct for a 225-235 section tyre but there's no way you'll get those on without modifying the arches. Indeed even when I ran 8" rims with stretched 205s I needed to have the front arch lips trimmed back to prevent arch fouling (although the car was also lowered 80mm) and the rears a lesser amount too. It's possibly also worth mentioning that I think every Corrado I've seen running 9" or wider has only done so with modified arches front & back. Indeed even some 7½" wheel designs (e.g. BBS RKII) grind the arch linings away so be a bit careful. Quote Share this post Link to post Share on other sites
yeti 0 Posted January 13, 2009 Just a quick point, i ran 215 40 16's of 16x7's (bbs rxii's) as that is the tire size that came out of the factory for a golf anniversary (Rolling radius 270mm) and the mk3 vr's run 205 50 15's from the factory which is the same as the corrado vr (rolling radius 270mm), are your current tire sizes not too big - 205 55 15 = 278mm static rolling radius are the 15's your runningn from a mk4 as they tend to have 55 profiles on a 6.5 rim Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted January 13, 2009 Im sure i have 205/45 on my 15" speedlines, is that ok? Quote Share this post Link to post Share on other sites
The_Dude 0 Posted January 13, 2009 the second number is the percentage of the first eg 205/50 means 50% of 205, which is 102.5mm. 45% is 92.25 so you have lost 10mm of sidewall. HTH. Quote Share this post Link to post Share on other sites
LisaK 0 Posted January 13, 2009 Who needs maths when google is your friend.... http://www.tyresave.co.uk/tyresize.html Quote Share this post Link to post Share on other sites
The_Dude 0 Posted January 13, 2009 boo, google is cheating! Quote Share this post Link to post Share on other sites
dinkus 10 Posted January 14, 2009 I would have interjected here that there's a link to a wheel and tyre bible in the wiki, which includes a calculator to work out all this kind of thing. But as the wiki's semi-dead at the moment Lisa's link will do the job. :lol: This link for the terminally geeky though - http://www.carbibles.com/tyre_bible.html Quote Share this post Link to post Share on other sites
corozin 0 Posted January 15, 2009 dinkus said: I would have interjected here that there's a link to a wheel and tyre bible in the wiki, which includes a calculator to work out all this kind of thing. But as the wiki's semi-dead at the moment Lisa's link will do the job. :lol: This link for the terminally geeky though - http://www.carbibles.com/tyre_bible.html Where's the fun in looking it up on a Wiki? Takes all the fun out of being opinionated it does! :D Quote Share this post Link to post Share on other sites
cvw74 0 Posted January 19, 2009 thanks for the help, now gotta decide 16 or 17 :confused4: :shock: :cuckoo: Quote Share this post Link to post Share on other sites
