fla
wheel balancing with front spacers
If you have spacers on the front wheels (not hubcentric) can the wheels be balanced to eliminate steering wheel vibration? At motorway speeds i get this on my car with 5mm spacers at the front.
You shouldn't need to balance the spacers with the wheels, that would be like doing the brake discs etc too which should be done at manufacture...
The reason your getting the vibration is that they are not hubcentric but i'm not sure you can get these less than 10mm
