russlench
16v alternator disassembly
I have a spare alternator that I am in the process of polishing. I am however stuck trying to split the parts below:
The innards seem to be screwed/bolted to the casing from the inside (white arrows)- unless this is just to enclose the bearing, and the casing can just be pressed away. I don't want to risk forcing it, so if anyone can shed any light on how I can separate these I would be grateful.
came across this issue myself, I think the bearing needs pressing out, probably a good time to get an engineering shop to put new bearings in it anyway, while it's in bits.
