myles 0 Posted January 26, 2009 lads can anyone help me indetify a vw gearbox please. 3 numbers. stamped on top plate. fvs 19101 371020 inside bellhousing. ww07 02j301107c beside drive flange. 02j 301103fp5 r1 02a is on the rubber plug on top and also stamped on the bearing behind the clutch arm. thanks lads Quote Share this post Link to post Share on other sites
davidwort 0 Posted January 26, 2009 well it's an 02J, as they are later items than the 02A although share 02A parts, hence the numbers with 02A on. What size are the drive flanges? - probably mk4 bigger 110mm ones (100mm on Corrado/mk3) Quote Share this post Link to post Share on other sites
myles 0 Posted January 26, 2009 david, flanges are 110mm . could this be a 6sp box. how could i tell , thanks, Quote Share this post Link to post Share on other sites
davidwort 0 Posted January 26, 2009 mm, FVS is the box code and the number indicates a 2001 box, it's not a golf mk4 one though. mk4's have an FBS, FBX, FBK, FBV 6 speed is DRW ERR EFF ah, a 2WD TT 5sp box is EVS, could it be that? Quote Share this post Link to post Share on other sites
myles 0 Posted January 26, 2009 david, it could be. the engine in the car is an aum which he said came out of a low mileage tt180. so its only a five speed , mystery solved i'd say !! Quote Share this post Link to post Share on other sites
