mikehiow
Windscreen heater
I'm having a few issues with my heaters,
Firstly when the dial is set onto windscreen, there is no air being blown onto the screen at all, as far as I can tell. What does happen however, is get very very hot behind the stereo, so much so I couldn't hold the stereo when pulling it out.
This is another issue, the stereo doesn't seem to fit properly, is there a restriction of the depth of a stereo that can be used?
Lastly, I'm not sure if it's related, but I can't seem to select front vents only.
Any help/advice would be much appreciated,
Cheers,
Mike.
Sounds like your trunking has been dislodged... Case of removing as much dash as you're brave enough to do and putting it back!
