camper driver
front CV joint removal
the stub axle has snapped on the front ns CV joint. Ive got the drive shaft removed from the hub assembly but cant get the cv joint off the end of the drive shaft. Ive been beeting it with a hammer and chisel but it wont budge!!!!!
sounds like something is majorly bent, the CV joint should just tap off the end of the shaft with a knock from behind when held straight, it's only a spring clip holding it in place.
something is majorly bent.........tap off the end of the shaft........... knock from behind.........holding it in place!!
:norty: Snigger............ :ignore:
colin you filthy boy!
yeah as david stubbs - check my mammoth project thread for pics (you might have to forage through the pages though!) as I've done that a few months back. Might give you some pointers?
Jon.
Jon.
You may want to edit that boost monkey!!!!!
