TDK
squeaky breaks
front or rear?
apparently the rear calipers are prone to seizing, mine does it too if i've had the handbreak on for a while.
- quick fix: grease the break disk's! :D
right the handbreak light comes on when you pull the handbreak on when you take handbreak off the light goes out but can flicker very slightly?
i think its the front breaks they dont' squeall the time just do a bit
If its not too bad you could try taking out the front pads and putting some copper grease on the areas of the pads that make contact with the caliper (not the disk!!). This helps stop the squeeking noise caused by the vibrations i believe.
good luck
