Majik
What can be done to improve idling on the G60?
Alright the car starts up alright from cold and idles at a steady rev but it feels a little lumpy when revving the engine so i need to know what to look for, what to clean out and what to replace to get a smoother idle?
Current weather conditions may have highlighted dodgy plug leads & distributor cap. When it's running "lumpy" have a look under the bonnet & see if you can see any of the leads shorting out - easier to see after dark.
Others to look for are:-
Fuel filter (change every 2 years)
Dirty Idle Stabilisation Valve - fits on top of cam cover.
Faulty blue temp sender
Incorrect timing adjustment
Ageing/incorrect spark plugs - essential to use Bosch W6DPO on a G60
Faulty Knock sensor - or damaged wiring
Unusual for a G60 to idle badly. All the ones I've driven have a rock steady and smooth idle....something the VR6 should learn by!
Kev
