drewiee99
schrick sump+windage tray
hi all ive managed to fit a schrick sump and a windage tray on my g60, lets hope it dosent leak this time. Is there a sequence you should use to tighten the bolts ? and also does anyone know the oil capicity as its a slightly bigger sump?
they're only piddly little bolts, very low torque so I can't see a torquing sequence is needed, probably best to very gently tighten with threadlock, especially on the windage tray that has an integral rubber seal as the sump gasket.
If you have a very low range torque wrench then that would be good.
well my passat haynes manual doesn't mention a sequence and I've never used a particular sequence and I've done both standard gaskets and windage trays with the integral seal and never had any problems.
