MFP
Help! Strange noises coming from steering
Hi,
I have a 95 VR6 and the steering groans and creaks at low speeds, most noticeably when I am parking the car, it is fine at normal speeds. Anybody have any idea what it is and roughly how costly it might be to repair? Thank's for any help.
Matt :)
Thank's for your reply,it wouldn't be some kind of steering joint that's worn and needs replacing then? I will check the PAS fluid and the pump you mentioned though. Cheer's Matt
could be, whip off the trays under the steering column and have a look, there should be a u-joint near the floor somewhere iirc?
