Corradam
How much boost?
We're nearing completion on a 20vt conversion for a friend using an AGU engine with K03s turbo and larger injectors (315cc I think). Management is via qpeng with a suitable map. After a couple of test drives boost seems to be peaking just above 20psi (seems a little excessive) before cutting back to around 16-17psi. Does this sound accurate or do we have a problem? All else seems spot on and very driveable. Any info really would be appreciated at this late stage of the conversion.
Sounds right to me mate, its a high boost level as its only a small turbo so the only way to get some power from them.
